SOURCE: staple,nail gun, how do i install the nail properly
SHOULD BE A SPRING LOADED TAB LOCATED USUALLY AT THE REAR OF THE GUN. PRESS IN THEN DOWN AND SOULD POP OUT SO YOU CAN LOAD.
PLEASE RATE
THANKS
SOURCE: How do you load nails into a stanley tre550 nail
there should be a button on the bottom rear of the gun, when you press it, it should release a bar that you pull back. the nails go in the dirction you nail them. sometimes the clips are too big for the guns and you have to break about an inch off of them
SOURCE: how do you load nails?
The staples
are NOT loaded on top of the pull out shaft; they are inserted directly
into the slot that opens when you pull the shaft out. If the nose of
the tool is not placed firmly against a surface, it will not fire.
CLICK HERE
and click the PDF icon on the right of the model # to start the download.
Here is a step by step:
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pull
out the shaft.
Flip the tool over on it’s back.
Insert the staples,
(points up) and then slide the shaft back in.
Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: how do you load nails in stanley tr250 staple and
The magazine on the TR250 has a recess on one side as well as a relief at the top where the driver pushes them through the opening. Load the brads/nails on that side of the magazine and it should operate properly. AS A REMINDER: ALWAYS REMOVE NAILS/STAPLES/BRADS WHEN NOT IN USE AS THIS WILL WEAKEN THE SPRING AND CAUSE FEED PROBLEMS IN THE FUTURE.
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
