Connect speakers to computer audio output.
Howdy Anonymous,
Generally the cord for lap-top speakers
(safely stuck in the side of your laptop
(head-phone jack))... 3.5mm
(tip, ring & sleeve (three conductor plug: both ends)).
Since you didn't DISCLOSE your make & model...
I'll tell you about mine... BOSE, MediaMate similar to
BOSE's newer Companion... Similar to these
Amazon com Bose Companion 2 Series III Multimedia Speakers for PC with 3...
But older than dirt... Balance & Volume ...Still sound terrific...
Exactly like these:
BOSE MediaMate White Computer Bookshelf Desk Speakers eBay
The speaker has it's own power source and the
"MATE" has no knobs, plugs or switches...
So if you have sound on your head set you are good to go with these speakers...
Helpful...??
Carnac the Magnificent
Note: Some speakers get power using a USB cable instead of an AC adapter. Ensure that the computer is powered on, and try a different USB port, if available. Both the USB cable and audio cable must be connected for the speakers to work properly.
Testimonial: "Thank you.Sorry did not note down the name who showed me with the connection picture that helped immediately. Thanks fixya."
SOURCE: Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
SOURCE: How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
SOURCE: logitech x 540 speakers wont detect on my pc (dell inspiron 530)
Here is the DELL support page for your computer and the logitech drivers and software needed.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSP_DSKTP_D530&os=WLH&osl=en&catid=&impid=
SOURCE: Dell monitor attached to Inspiron 1520 runs landscape (sideways)
try CNTL+ALT+Up arrow/Down Arrow
SOURCE: connect external pc speakers to flat screen tv
get a 3.5mm -> rca adapter. You need to convert from the 3.5mm jack that your speakers uses to the rca jacks that your tv expects.
Like this:
http://ecx.images-amazon.com/images/I/31TelR%2BsCYL._SS400_.jpg
I am sorry. I did not make myself clear. Somehow one end of the audio cable came loose . My problem is one end of the audio cable is safely plugged into the computer. where does the other end go? Thanks. Please help me asap.
