Question about Hotpoint Microwave Ovens
HOTPOINT MWH 27343 B Combination Micro How do we use it as an oven? Very confusing
Door for oven opens freely now.. im looking for a quik way to fix this issue without taking the whole unit off my wall..... Model # KEMS376BTLO
I am confused as to what issue you are having, this unit is a micro combo and which unit are you having issues with? Micro has a handle for a door release and oven has a pull door handle. Please get back to me with more information so I can assist you.
Also Model number is KEMS376 ------- starts with S or T
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 02, 2013 | Microwave Ovens
How do I change the filter on the Hotpoint RVM1535WMCo01 microwave oven. When I took the top off I can not see a filter to replace. Does that mean that I have been running the Micro for the last year...
Microwave ovens produce dangerous emissions and require servicing by qualified technicians.
I suggest purchase a new one rather than repair because most microwave models cost as much to repair as simply buying a new one.
Nov 02, 2017 | GE Hotpoint RVM1535 Microwave Oven
MICRO WAVE IS NOT HEATING. Light works; table turns but not heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 14, 2010 | Hotpoint RVM1435 Microwave Oven
Hotpoint RVM1435 when I push start button will not start unit?
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Hotpoint RVM1435 Microwave Oven
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
How do you replace intermittent door switch on Hotpoint RVM1335BC001 microwave
Open the Micro door, and remove the air/Vent cover on the top if there is one, Usualy 2 screws on top or the middle of the cover.
Remove the screw holding the Controller board and then you will have access to the door switches 2-3 of them depending on Manif.
Also make sure you have the power unpluged befoe you do any of this.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 27, 2009 | Hotpoint RVM1635 Microwave Oven
Hotpoint Counter Saver Microwave not working
Please do not try to service. its dangerous to play with the internal parts of a Micro Wave. Most counter tops are pretty inexpensive buy a new one if the warranty is out.
Sincerely Steve
May 29, 2009 | Hotpoint RVM1435 Microwave Oven
Hotpoint microvave won't start rvm125j
Have same problem tech tested some components and gave up (i think) and just called it a circuit board problem. I have a service plan so the whole microwave is being replaced as it is apparently cheaper for the warranty company.
Jun 16, 2008 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
257 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Gerry Harvey
Gerry Harvey
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
