Computers & Internet Logo
Joe Tirado Posted on Aug 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to work pave7287 I replaced battery forgot how to setup up time date
RevMarket
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 50 Answers
  • Posted on Sep 11, 2017
RevMarket
Expert
Level 2:
Cheetah:
Answers
50
Questions
0
Helped
20152
Points
109
Using command prompt.
Go to CMOS settings in BIOS.
Rick Hickerson
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 119 Answers
Rick Hickerson
Expert
Level 2:
New Friend:
Greenhorn:
Answers
119
Questions
0
Helped
10273
Points
254
Enter the bios and set the time and date there. To enter bios setup pressing the delete key at power up usually works.
1 Related Answer
Anonymous
  • 1913 Answers
  • Posted on Apr 03, 2008
SOURCE: System Time/Date in BIOS setup not functional
reset your bios with jumper settings.
My watch not working how to setup
  1. Check the battery: Before attempting to set up your watch, make sure that the battery has not run down. If the battery is dead, you will need to have it replaced by a professional watchmaker or authorized Breitling service center.
  2. Wind the watch: If the battery is not dead, you may need to wind the watch to get it started. Most Breitling watches have a self-winding mechanism, but if it has not been worn for a long time, it may need to be manually wound.
  3. Set the time: Once the watch is running, you can set the time by pulling out the crown (the knob on the side of the watch) and turning it until the hands are set to the correct time. Push the crown back in when the time is set.
  4. Set the date: If your watch has a date function, you can set the date by pulling the crown out to the second position and turning it until the date changes. Push the crown back in when the date is set.
  5. Synchronize the time: If your watch has a chronograph function (stopwatch), you may need to synchronize the time to ensure that it is accurate. You can do this by starting the chronograph and waiting for it to complete a full revolution.
Feb 12, 2023 • Watches
Dear sir i have a pc And i forgot the bios password of that How can i remove the bios password from the gigabyte Ga-ep31-ds3l mother bord Tnx
First, you must unplug your PC out of electricity supply and remove mainboard battery, waiting a minute. And then you setup battery again. So that you can remove bios password. May be you must setup date and time on your PC. wish you success.
GET LOW BATTERY MESSAGE AND WRONG DATE/TIME WHEN BOOTING - TRIED REPLACING BATTERY SEVERAL TIMES BUT STILL SAME PROBLEM - DIMENSION 9150 WORKS FINE APART FROM THIS
the CMOS battery of your computer is depleted.. Try to change it to save your BIOS setup including your time and date setting.
1helpful
When i boot my system iam getting an error Check Date and Time settings and System CMOS Checksum Bad and Default configuration is used. F1 : Resume F2 :- Setup
Hi Good day!! That error maybe cause of your CMOS battery it may be not working, replace your CMOS Battery (2032 3volts), after you replace it with new one, set your date and time setting according in your time zone.
2helpful
2answers
I have a Gateway laptop model no. M622-UCX which continues to prompt for the system date configuration in cmos setup during start. It also cannot remember the date and time I entered several times and...
When a laptop/computer prompts for a BIOS date and Time setting every time you boot up, this indicates the BIOS battey is flat or nearly flat. This BIOS battery needs to be replaced and the BIOS Date and Time setting needs to be configured etc.
2helpful
2answers
Setting Date/Time on Polaroid a530
I contacted Polaroid help desk and they were clueless. They said there is no way to set the time after messing around with the camera for 10 minutes.
When you pull the photos off the camera it does record a date and time. I believe they forgot to add the option in the setup menu so you cannot get to it. I asked for them to send me a differant camera and the help desk rep laughed.
I guess thats what I get for buying a cheap camera.
2helpful
How to know dell 370 precision battery
If the battery is changed, that will mean that the BIOS was set back to january 1 1980.
Go into BIOS, set the clock to the correct time.
For DELL 370 precision , here is the BIOS instruction:
http://support.dell.com/support/edocs/systems/ws370/
Replacing the Battery caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. notice.gif NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface on the computer.
A coin-cell battery maintains computer configuration, date, and time information. The battery can last several years.
The battery may need replacing if you have repeatedly reset the time and date information after turning on the computer or if one of the following messages appear:
Time-of-day not set - please run SETUP program
or
Invalid configuration information -
or
Strike the F1 key to continue,
F2 to run the setup utility
To determine whether you need to replace the battery, reenter the time and date in system setup and exit the program to save the information. Turn off your computer and disconnect it from the electrical outlet for a few hours; then reconnect the computer, turn it on, and enter system setup. If the date and time are not correct in system setup, replace the battery.
You can operate your computer without a battery; however, without a battery, the configuration information is erased if the computer is turned off or unplugged from the electrical outlet. In this case, you must enter system setup and reset the configuration options.
2answers
BIOS setup won't allow me to set the system time and date for Asus m2n-sli deluxe motherboard.
dear friend
u try system date with windows time and date and then trun off yr pc and put off yr power cable for 10 20 sec then plug on power then try if system date still not work then changer for Mother boad BETTRY it's 2032 number bettry try this one
thanks for using fixya
jo_chinmay
7helpful
3answers
Dell dimension 4300 forgot main password
Get a motherboard manual from Dell.com.
Look for jumper 1.
remove jumper 1.
Power on.
Wait till PC powered on then power off.
Replace jumper.
this will reset ALL BIOS setting including password.
Please let me know if this helps.
Top Time Computers & Internet Experts
Thomas Perkins
Thomas Perkins
NOEL
NOEL
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
