TV was working fine until I pushed input button, then the picture went to double image. It has a double image on all inputs. RUKU, TV, CABLE, and DVD. Can this be fixed by a setting or reset?
SOURCE: double image.
you have hd65w20 selenium? this is a dt307 rca chasis. Why did you replace 257154 which is called delection sip. this has little with convergence... was convergence the orginal complant?
SOURCE: Trying to connect laptop to
Hi!
First let's be sure that video signal is coming out of your laptop. You did nor mention your laptop make/model and the connection cable type you are using between laptop and TV (VGA or HDMI or S-Video ). I'll assume it is a common VGA cable.
Now, on every laptop the user can choose where the image is displayed: on the laptop only, on the external monitor/TV/projector or on both displays. This can be done by pressing the Fn key toghether with one of the F1 to F12 keys. Usualy it is Fn and F5, but other laptops use other key instead of F5. (please check the icons on your Fx keys, there must be something like two displays side by side). Each time the keys combination is pressed, the image switches between the 3 positions: only laptop, only external, or both displays.
Please let me know if it helped.
If you are using something else than VGA cable, please post again also mentioning what type of laptop you have.
Regards,
Bogdan
