SOURCE: Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
SOURCE: GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
SOURCE: not acquiring satellites
my GPS map 60CSX is not acquiring satellites. It was working fine until most recent power up.
SOURCE: No Reception with Garmin Quest
You can find a discription how to reset the GPS here (http://www.elsinga.net/quest-first-aid).
I've already tried it and all the suggested solutions like discharging the battery, changing the date, ... , but it diden't help.
littletramp on worldtrip
SOURCE: combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
