SOURCE: Loading Australian Maps on Nuvi 200
She can purchase the City Navigator Australia DVD and load the Australian maps onto an SD card. Insert this into the unit and she'll then have both S Africa and Australia maps.
SOURCE: garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
SOURCE: Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
SOURCE: Garmin Nuvi 205 can't unlock maps
First, check to make sure the map file is there. The file name is gmapprom.img. It's located in the Garmin directory. It should be 1GB in size. To do this you need to connect the Nuvi to a PC with a USB cable.
Next, please tell me what year of map you have on your unit, 2009, 2010, etc.
Them, email me your units internal serial number. Its a 10 digit number (not the number on the outside). The number starts with a "3" and can be found by pressing the tools button, then system and then "about".
Please email me at sharcnet-usa AT sharc DOT NET
- Jim
SOURCE: garmin 1300 stuck on maps loading frozen
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
