Question about Ranger Radio Communications
How do I convert a Ranger SS39 10 meter radio to 11 meters?
6ya staff
SOURCE:
Mechanic688
Mechanic688
  • 204 Answers
SOURCE: wiring diagram
Hello birdhunter, no the cobra 200 has the same pinout as the 29's and such, but the color code might be different.
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
STOCK Pinout Let me know how you get along with it,,,, Mechanic
1- Shield
2- Audio
3- Transmit
4- Receive
Posted on Oct 31, 2008
Mechanic688
Mechanic688
  • 204 Answers
SOURCE: will not stay on 11 meter turn it off comes back on 10&12 meter will not transmit am or ssb recieve ok. rci 2995dx.
Hello janetsue, If this radio has the blue or green screen LCD face then this is a default that is built into the radio. It depends on how the radio was "converted" when it was bought new.
It will not key up on 10 or 12 because of the default. A little more info supplied would be real helpful,,,, Let me know, Mechanic
Posted on Nov 01, 2008
Anonymous
  • 120 Answers
SOURCE: 11 meter band on a ranger 2995Dx radio
Ebay (sorry i couldn't resist)
Posted on Jan 10, 2009
Anonymous
SOURCE: need mod for 11 meter ts 830 s
As far as I know there is no mod and it illegal to put out that kind of wattage on 11M anyway...
Posted on Feb 02, 2010
pimas
SOURCE: How do I get 11
I just bought one and it came with a adatptor in heat shrink
Posted on Mar 24, 2010
Converting 10 meter to 11 meter on Connex CX-3400HP CB RADIO
Turn the mode switch to the setting you want and leave it there .
Jan 10, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
I am looking to buy Ranger RHF-618 10TO 12 METER CB
do you have a ham license? when you purchase it they sometimes ask for proof .
Jun 09, 2013 | Ranger Communications RCI-6900F-25 CB...
Convert connex 3300 fhp to 11 meter
FOR ALL YOU MISS GUIDED FOLKS CONNEX IS NOT PART OF COBRA IN ANY WAY SHAPE OF FORM PERIOD ...CONNEX IS MADE BY RANGER U S A . AS FAR AS THE RECEIVE IT IS PROBABLY ARE MISSED SWITCH OR CONTROL NOT SET RIGHT SIR
Oct 18, 2012 | Connex 3300 240-Channels Base CB Radio
Is it possible to convert the cobra 29 wx nw st sound tracker cb to 10 meter amateur band?
No it cannot. If you want that buy a Ranger or a Galaxy.
The 29 can be altered to increase modulation and turned down in power to match it to amp for increased output of power.
Set to dead key a watt or so with a 100 watt amp it would dead key low and swing to 80 to 100 watts pep.(peak envelope power)
Mar 16, 2012 | Cobra Radio Communications
Convert to a 11 meter band radio.
CB............... citizen band is 11 meter.
That is an 11 meter with Single Side Band radio.
Sep 02, 2011 | Ranger TR-966 CB Radio
Will the 257 work on 11 meters/cb40 channels?
The Magnum 257 is a 10-meter Amateur radio, but it can be easily modified to operate on the 11-meter CB radio band. The modification and use of this radio on the CB frequencies is, of course, illegal. To modify one of the newer blue-faced models (this will not work on the original yellow-face models), remove the speaker side cover and look for the CPU board in the front of the radio close to the mic connector. This board has four sets of pins and a jumper that fits on the pins. To convert/expand the radio, move the connector to the CON3 position. This will give you frequency coverage from 25.165 to 29.699 MHZ, and the CB frequencies will be on Band E of the radio. Again, this modification, and use of the radio on the CB frequencies, is illegal. This modification information is provided for shop/calibration and experimental use only.
Nov 01, 2010 | Magnum 257 CB Radio
Information on how to use DX 45MP radio
The DX 45mp is a 10 meter radio meaning you need a license to use any other band other than the normal 1- 40 cb channels, its capable of going beyond the normal cb range.Ask if it has been converted to 11 meter. Channel E should be the normal if it has been converted from 10 meter to 11 meter. Im sure its been converted if its been used for a mobile cb application. Normal cb band is called 11 meter 26.965 mhz to 27.405 thats 1- 40 . Your not supposed to talk on the other bands unless you have an amature radio license but everyone does anyway . I have several galaxys and by far in my opinion are the best on the market. Go to www.cbtricks.com on the home page go to Radio Informaion click it go to G and follow it to Galaxy DX radios youll find all the info for this radio you can even print out the channel chart to see where everything is. Good luck and if you have any more questions just ask. Thank you Chia
Nov 05, 2008 | Radio Communications
Will not stay on 11 meter turn it off comes back on 10&12 meter will not transmit am or ssb recieve ok. rci 2995dx.
Nov 01, 2008 | Ranger RCI-2995DX Base Scanner
10 meter portable
There is no factory made 10 meter CB Radio made for US use. CB Radios use 11 meters, and the FCC doesn't allow the combination of 10 and 11 meter radios combines. Although, many people modify 10 meter radios to work on the 11 meter ( CB ) band, it's not legal. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 15, 2007 | Magnum 257 CB Radio
Radio Communications Logo
126 people viewed this question
Top Ranger Radio Communications Experts
Mike Charette
normis101
Robert McClure
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
