Washing Machines Logo
Frank Perri Posted on Aug 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1 of the fins of the agitator of my speed queen hd washer broke off. It's only about 2 or 3 years old. How is the fix?
Lollo Pop
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 134 Answers
  • Posted on Oct 31, 2018
Lollo Pop
Expert
Level 2:
Cheetah:
Answers
134
Questions
0
Helped
73740
Points
301
5 Related Answers
Anonymous
  • 156 Answers
  • Posted on Feb 25, 2008
SOURCE: Green grease? stains from my older Speed Queen washer.
your seals and gear case needs replaced
Terry Schneider
  • 177 Answers
  • Posted on Jul 16, 2008
SOURCE: 2 problems with speed queen washing machine
The motor is not starting this is the humming noise not a good sound, try it in spin to see if the motor runs in this direction. You may have a motor issue because of the water leaking on the motor?
Now that you have the front panel removed you can look for leaks, you will need a flash lite, start a cycle on the small setting and look for where the water is coming from. If it is coming from the center of the tub above an aluminum case which is the transmission you need a tub seal, if the water is coming from somewhere else it could be a pump, or hose, or ?
Terry Schneider
  • 177 Answers
  • Posted on Aug 22, 2008
SOURCE: Draining water from inside through center.
The tub seal kit is $85 USD, You will also need a drive bell kit$23 USD, you should replace the upper bearing $?, for a complete rebuilt I would also replace the brake pads all three, and the belt, maybe the pump if it doesnt come off easily. Plus what you break taking it apart, so we are looking @ least $150.
Yes you can do it yourself, you dont need the tub wrench if you can borrow a deep socket, its the drive bell seal tool you really need.
Please let me know if you have additional questions. the serial number will tell you the age first two digits are year next two are month, starts with and R, built in Ripon WI.
prasanth83
Prasanth Prabhakar
  • 68 Answers
  • Posted on May 13, 2009
SOURCE: Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
Anonymous
  • Posted on Jan 13, 2010
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
3helpful
2answers
Speed Queen Washer AWNE92. Agitate runs full speed on delicate cycles. Have tried unplugging and such. Any ideas?
Speed Queen AWN542 using the delicate cycle. Provides a brief
wash, 3 minute pause, quick agitation, then slow speed spin drain.
https://www.youtube.com/watch?v=VRyowST7tYo
1helpful
All of the fins broke off of my agitator and my machine is only 3 years old.
what were you washing? You can get a new agitator, go to searspartsdirect.com and put in the model number to pull up a diagram.
2helpful
Will not start washing process
Is the belt broke?
If not, will it spin it you put it in spin mode?
If it spins, but not agitates, the transmission is locked up in agitation and needs replaced. This is a major undertaking.
Won't drain - no pumping sounds at all
if agitates an does not spin means is not going to drain, cause for not spinning broken door switch, look an see if you can feel it hanging or loose, if the swtich is broken it will not go into spin mode at all...........door switch is a safety device!
4helpful
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
I have a maytag top load wash machine that has broke on me for the last time!!!! i want to get a speed queen to replace it. how do i go about getting a manual on a speed queen washer so i can see how they...
Click on Speed Queen above in blue...............front loaders would be nice. But ask the dealer where the filter is, what the codes mean, etc. These are all supposed to be secret - so their techs can come around to make more money..... No jokes its real.
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Speed queen top loader
You should be able to get a replacement agitator from partselect.com or repairclinic.com. look on line for an agitator however How old is the washer, would you give me the serial number.
T
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
