You can do a battery upgrade from the standard 10AH battery to 12AH or even 15AH. The larger the Amp Hour rating is, the longer the battery will last. Also worth pointing out the battery deteriorate with age and how well they are maintained. Long periods left flat will damage their ability to hold a charge.
Fuses will most likely be located in a fuse block under one of the body plastics, most often they are on the left side of the bike/scooter. They are as simple as pulling them out and putting in any new ones. You can easily see if they are blown as the metal bit in the middle will be broken or melted.
Hi, if you use this link you will be able to find what you need to know,
http://cart.electricscooterparts.com/v/searchresult.asp?sw=how+far+will+one+charge+take+me
Schwinn is a American company, so have no fear of your propose situation happening. But removing the chain is simple just un screw the motor and pull it out. After that the chain will be lose. And for changing the tire follow my tire changing guide.
