101/68 heart is 84 well I don't want to be a hypochondriac lol
Notify your doctor for medical or health information
Always, your own physician is the best source of information. If you are feeling fine, the general guideline is blood pressure not lower than 90/60.
The Basics of Low Blood Pressure
SOURCE: WHAT WOULD BE CONSIDERED LOW BLOOD PRESSURE?
There are standard methods for measuring BP. One should be seated on chair, feet on ground, leaned back, relaxed for at least 5 minutes, at least 2 hrs after a meal, .... then repeating this procedure several times daily, and averaging will provide some ave daily BP value.
Using this procedure for hourly BP measures, one can adjust times and doses of BP medicines taken daily.
SOURCE: supply air is 74 degrees???????? low side
Because you have a ductwork problem. Look for leaks in the supply lines or a dirty coil not allowing sufficient airflow.
SOURCE: What should blood pressure be for a 65 year old female?
Like the old guidelines, the new guidelines recommend that adults ages 30 to 59 should get treatment if their blood pressure is above 140/90 mm Hg.
However, the new guidelines do give adults ages 60 and older a bit more leeway. Treatment is not automatically recommended in this age group for people with blood pressures of 140-149/90, unless they have diabetes or kidney disease.
You should discuss this with your health professional and follow their guidance and treatment plan.
SOURCE: please advisenormal blood pressure for active 84 year old female
no such thing as normal blood pressure as every person is different
talk with you doctor and discuss what it would be for you
SOURCE: I am 75 years of age Male my blood preasure alters a lot at the moment it is is 160/80
It is normal for blood pressure to vary through the day. However that systolic (upper) reading is higher than ideal. It is important for people in our age group (I'm 70) to have BP looked after because our plumbing is not what it used to be. However the general wisdom seems to be that you also don't want very aggressive treatment which causes a large drop in BP.
By the sounds of it you might have a home BP meter, but if not, consider buying one. I found mine very informative, both for me and the doc.
Go see a doctor for advice and supervision and stick with that.
