Roper REX4634KQ Electric Dryer Logo
Posted on Jul 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer has some heat but is taking a long time to dry clothes
Our dryer is an electric roper. it is putting off some heat but not enough to dry the clothes in one cycle. so far it is taking about 3 -4 cycles to dry them. any ideas?
Anonymous
Level 3:
President:
  • Master 1,776 Answers
  • Posted on Jul 27, 2009
Anonymous
Master
Level 3:
President:
Answers
1776
Questions
0
Helped
646796
Points
6310
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
1helpful
No heat/Only works on one setting
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
It takes at least 2 cycles to dry clothes. It is Roper heavy duty high capacity electric dryer. Thank you for any help you can give me. [email protected]
Check for air restrictions which cause the heat control to shut down faster than normal.
When the moisture cannot be removed fast enough the heat builds up and has nowhere to go so the heat control stays off longer and the clothes just tumble on.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
2helpful
2answers
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
What would cause intermittant heating in a Roper Electric Home Dryer?
the dryer vent, not the parts behind the dryer, where it goes into the wall to where the vent leaves the house has lint build up in it. this will cause the element to short cycle cause long dry times. if its really bad ive seen people have to run dryer 3 or 4 times to get clothes dry. clean out vent. this should solve problem
6helpful
3answers
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
