SOURCE: my nextar x3-08 wont read the sd card
I called Nextar and you have to let its battery drain completely and then plug it in to charge for 5 hours. I guess it a glitch in the system :(
SOURCE: Magellan roadmate 1412 just stop working and
Providing you saved the SD card info as soon as you got it, reformat the SD card and copy the files over. Or find a friend that has the same unit and copy their files. Reformat your card before also.
SOURCE: When I turn on my
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
your map data was stored in the lost sd card and replacing that you wont find the data again so reinstall the map software
SOURCE: I have a Nokia 500 gps system. The sd card with
You can put the card out of your device and then connect to the PC follow the steps list in this article.
http://www.goshareware.com/resource/recover-deleted-files-from-sd-card.html
