SOURCE: sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
SOURCE: MY SHARP AR-5320E COPPIER SHOWING CH ERROR CODE
Some part/ unit (developer, drum, imaging unit, fuser) or something else is
not installed properly or is not plugged into the machine. Check all
assemblies that can be removed from the copier, and make sure they are
installed and plugged in properly.
The 'ch' code will automatically
reset when the fault is found.
SOURCE: SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
