How can i change my old number resetting my new number
My old phone was stolen now icant find access gmail account because ilost everything my number,account and password please help i havent yet recieved my nsfas massege or sop.
You can all ways get your account back by using the email address you used to open it with . Then click on forgotten password, and follow instructions. If you have two email accounts you can not join them.
Try this link. https://www.google.com/accounts/recovery/skt .. It will ask if you remember an old password, if you don't select that option and it will ask you some other questions.
Using your old # is part of the security google has so no one else can access your account.
If you can't remember your phone # I think you're *******.
If you're trying to get into someone else's account stop before you get in trouble for hacking.
Google Email: Can't log in or access anything Google:
Hello. Yes, once you log into your Google Account, you will have access to all things Google. Without that account login you will not be able to access anything Google related except Google Internet Search.
As a temporary fix, so that you have access to Google Services, create a new Google account.. Settings>General>Accounts>Add Account>Google
so, think of another name you can create the new Google account to be.. I would pick your last name first then first name and a number (eg: [email protected])
i would use the same password or a password you can easily remember for the time being so that you don't get mixed up/confused
then use this new Gmail account to temporarily get Google services back. it won't be your original account with all your data, but at least it allows you access NOW to whatever you need it for (like to access Google Play Store so that you can install an application to use on your smartphone)
on a piece of paper or in a notepad app on your phone, write down your new Temporary use Gmail account name and password, so that you don't forget and so you can login again if need to. (We will log out when we try to fix your original account)
when you find time we can try to get back into your old account so that you can access your emails, phone contacts, etc that's stored in your original Gmail account
CreateNewGoogleAcct.mp4 (note: depending on the device used, manufacturer, Android software firmware version#, and cellular service provider.. the settings menu system may look a little different. Keep this in mind when following instructional tutorials of a different device then yours)
Procedure to: GET BACK INTO YOUR ORIGINAL GMAIL ACCOUNT:
Open your internet browser:
If you forgot your password, you can reset it, go here: Having trouble signing in
(to reset password, OR to get a hint to remember username)
(if need to, you can use your new alternate temporary Gmail account to have Google contact you)
or, you can use this Google Access Troubleshooting form: can access my account
(it looks like the image below)
** After you reset your password, then Go back to your phone settings: Settings>General>Accounts>Google.. Click on your original account name (not your new temp account) and enter your new password you reset to for your old account
*** You should be able to get back into your original account.. If YES!
..then we need to remove the temp account, so that we don't get confused and everything is back to normal.
(you can keep this info for your temp account login somewhere in case you need it again if want. or, use it as a dummy email for telemarketers, people who want your contact but you don't want to talk to, etc)
Go back to: Settings>General>Accounts>Google
tap on your temporary Gmail account name/address
Tap on the 3 dots (upper right corner):
Select "Remove account"
First you need to use computer to double check if you can access your google or gmail account by logging in. If you can not log in to your google account or gmail account by using computer that means you enter wrong password. This can happen due to your google and gmail account has been hacked by another person who did logged using your password then after they logged in they changed the password and so on ...your profile info has been changed too.
If you can log in to your google or gmail using computer that means the problem is not your google gmail account issue the problem is your phone ( hardware problem) if you did reset your phone how do you reset it ? soft reset or hard reset ? Hard reset is reset and restore to manufacturing setting it would erase all of your personal data and restore your phone back to original setting. If you did this step but still having problem then i recommend you to borrow any smartphone ( from family member or your best friend ) use that phone try to access your google and gmail account. If you use difference phone and you can logged in and access your account then ...no need to say it is your phone having a problem ! Change to use a new sim card to see if problem fix if not ......then i think it about time you need to get another new phone.
Maybe, try setting-up a second Gmail account, then send transfer) your emails from the old username account to the new username account. If this works, then either try deleting the messages from the old gmail account and transfer the messages from the new gmail account back to the original gmail account ... or ... just delete the old gmail account if you successfully transferred them to the new gmail account.
reset your password as soon as possible by using these three options
1. reset your password using alternate email id
2. reset your password using security questions
3. reset your password using your phone number
you should be able to get your phone number back from your service operator, if stolen. then you can follow the password retrieval wizzard, via cell phone. usually, cell phone operators should be able to give you a new sim card within minutes, you just need to get to a shop to do that.
