SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
SOURCE: Got a Miele G2220sci dishwasher
F19 is water in the cabinet takes too long to heat up. you can reset the heater limiter..
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. If the fault message reappears
take off service panel press button on the heater limiter red-brown located on the left side of the plinth...
hope it helps
SOURCE: The motor does not engage in at all
The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
SOURCE: My Hotpoint Ultima super silent is occasionally
F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
SOURCE: hi, i have a hotpoint slimline SDW60 dishwasher
download the user guide here >> http://kitchen.manualsonline.com/manuals/mfg/hotpoint/hotpoint_dishwasher_product_list.html
