My Samsung LED has no picture, but there is sound. There is backlight and the tv displays more of a purple color rather than black when on. Do I need to replace the LED panel or is the problem another part (T-con board or power supply board)?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
The display panel should be suspected. The picture you attached here looks so. Contact the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: On my Hisense 50K23DG LED TV, I have sound but no picture.
Hisense TV's usually use PCB Boards by Vestel and not Hisense themselves, have a look at: Vestel Help If the Boards in your Hisense match this Board/Part Number format at least you'll know what to search for, replacing the power supply will not help unless the process has been incorporated into the power supply and that is not known for certain yet
Good Hunting
Do flashlight test to see if y0ou can see an image - if so replace the inverter board that powers backlights. If no image then go for the main board.
Some of the 32" & 40" Samsung LCD TV has the problem, the problem is weak florescent back lights tube, you need open the panel & replace the weak one.
