The plastic locker is one of storage cabinets, which is made of plastic materials. It can also be called as the sorting cabinet. This kind of plastic locker adopts the multilayer splicing design. Each layer has enough space for people to place a variety of items, which is very useful for the classification and arrangement of items and suitable for modern people's needs of home cleaning.
The advantages of plastic lockers
From the view of materials, the materials of the plastic locker are environmentally friendly. They are oil and acid resistant , non-toxic, tasteless and are very conducive to health.
From the view of convenience, generally there are wheels under the plastic locker. Thelocker is a piece of labor saving furniture, which is convenient for people to move it without needing too many efforts.
From the view of performance, the plastic locker can greatly save home space with light weight. It can be folded, disassembled and assembled, which is convenient for people to put it in order. When it is piled up, it also looks neat and beautiful. Also, it has great bearing strength. It is very cheap and is cost-effective, which make it a home essential.
How to choose the sizes of plastic lockers
The plastic locker has various forms and sizes. Customers can choose it according to their own interests and needs. The size of the place where the locker will be put should be measured in advance, and then the customer can measure the length, width and height of the actual locker when they purchase it. The locker usually adopts the multilayer design. The number of layers can be designed according to the actual needs of customers and it is not always fixed. The common sizes of lockers are: 33 X 43 X 63(cm), 57 X 42 X 98(cm), 50 X 45 X 79(cm).
Choose the sizes of lockers from the use of plastic lockers
The plastic locker is available in our daily life. If you use them to sort small items, you can buy small lockers. If you want to arrange more things, you can buy a multi-tier locker, and then sort item layer by layer. Some people use it to place the clothes, and there are also plastic lockers for clothes on the market now. You can choose lockers with different sizes for different use, and you can always find one suitable for your needs.
Plastic lockers are becoming more and more popular because they are highly cost-effective. Are you looking for such a locker? Plastic Locker Manufacturer ABS Locker Factory China Locker Company
Best and cheapest to fix is to replace vacuum lockers with manual lockers. It is easy to do. Only 6 bolts per front wheel. This is the most trusted way of 100% engagement.
