SOURCE: camcorder tape door opening
I had a problem the same as yours and I found the problem on the ribbon wire connected to the board where all the control button is located ( stop, rew, play, fwd pause). The problem occur because everytime you eject the tape from the loading mechanism the ribbon wire also move like your cutting it into pieces. sorry for my english hope you get the idea.... wait for the photo and i'll show you what i mean.. hope this will give you the solution you need.
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different
positions for the different modes. On time around is a play -
stop cycle. It is stuck in one position and won't come around to
the stop spot. Need to take the cover off and help it to turn to
get the cassette out. Then figure out if something is wrong
preventing it from turning or if the wheel driving it is the
problem. They are all a little different so this is where your
mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
SOURCE: tape not loading
Chances are it is in need of a major cleaning. Usually by the time this happens the cleaning tape will do no good. A good internal cleaning is usually the only thing that will help it........Has it been droped? If it has then you could need repairs
SOURCE: canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
SOURCE: tape stuck in camcorder
Turn off
Take battery out
plug in to power
turn on
Tape shoudl pop out.
it worked for me!
