Question about Canon Cameras
Canon d60 flash won't open - Canon Cameras
    Prodigy:
    An expert who has answered 500 questions.
  • Canon Expert
  • 512 Answers
Set the camera to mode M (manual) and press the flash release button
Posted on Jan 23, 2019
SOURCE:
My flash won't pop up.
Theres a button on the side of the camera with a lighting bolt on it push to open leave lens cap on to test then go to menu look for flash/ bracketing and set to open
Dec 19, 2012 | Nikon D60 Digital Camera
How slove the problem
Introduction
Specifications Recommendations
The Nikon D60 is an inexpensive 10 MP DSLR that comes with an excellent 18-55mm VR lens for about $650 as of June 2008. It was a announced in January, 2008, and sold for about $750 with lens in February 2008.
The Nikon D60 is a replacement for the almost identical D40x.
Personally I prefer Nikon's least expensive D40 over the D60 or D40x. The D60, D40x and D40 are actually exactly the same cameras, differering only slightly in their internal electronics, but differing greatly in their prices.
The D60 is actually a D40 body with a few more card-clogging pixels, a VR lens and adaptive dynamic range, but a slower maximum shutter speed with flash.
The D60 is less sensitive to light then the D40 (its default ISO is only ISO 100 compared to the D40's default ISO of 200). Its less sensitive to light because the pixels have to be made smaller to cram more of them into the same-sized sensor. Smaller pixels collect fewer photons than larger pixels. Since the D60 is half as light sensitive, the D60 has to use twice as long a shutter speed or a larger aperture, which makes it more likely to make a blurry picture than the D40. OOPS!
Save your money and get the D40 instead. The D40's faster sync speed is invaluable for use with flash outdoors, and the extra light sensitivity in normal use will help make sharper pictures. These three cameras (D40, D40x, D60) otherwise, for most users, are identical. Compare them in person and you'll see. Megapixels don't matter.
(I detail the few fine points which are new in the D60 further below.)
I had my hands on a D60 back in January 2008. The D60 is an excellent camera, but for most of the people who will buy it, it's the same thing as the $300 less expensive D40. I'd suggest getting a D40 and putting the $300 towards more lenses and/or a bouncable flash.
In fact, the faster flash sync speed (the fastest shutter speed with flash) is more than twice as fast in the D40 (1/500 vs. 1/200), and along with the faster base ISO, the D40 is more likely to make sharper photos for most people, for hundreds of dollars less!
The only significant feature in the D60 over the D40x and D40 is adaptive dynamic range. The D60 does not have any of the other next-generation functionality of the D3 and D300.
The D60 is just a D40 with more pixels, but slower shutter speeds with flash outdoors and less basic light sensitivity due to the smaller pixels needed to jam more of them onto the same-sized sensor.
I make excellent 12 x 18" (30 x 50 cm) prints from my 6 MP D40; do you plan to print bigger? Really? The resolution makes no difference unless I'm printing at 20 x 30" (60 x 80 cm) or more.
Since the D60 costs $300 more than the D40, I'd much rather have a D40, 1/500 flash sync for better daylight fill-flash range, a minimum ISO of 200 and $300 left over to buy lenses and an external flash that I can bounce for better lighting. For instance, the D40, 55-200mm VR and SB-400 is a far better way to spend the same $750.
Sep 19, 2011 | Nikon D60 Digital Camera
I bought an 18 megapixel d60, is there a new 20 megapixel d60 in the market,,if there is, do i need to buy a newer d60 just to increase its megapixel
There would be almost no noticeable difference between an 18 megapixel camera and a 20 megapixel camera. Personally, I would look for a camera with a fast shutter speed and a high Optical Zoom.
The Canon EOS D60 is a discontinued 6.3 megapixel digital single lens reflex (DSLR) camera.
The Canon EOS 40D is a 10.1 megapixel digital single lens reflex camera.
The Canon EOS 1D Mark III is a 21.1 megapixel digital single lens reflex camera, and is the first to break the 20 megapixel barrier.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 14, 2011 | Cameras
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
Hello i have nikon d60 and the flash do not pup out
In what mode(s)? In the point&shoot modes the camera decides whether to pop up the flash. In PSAM modes you decide.
Dec 25, 2009 | Nikon D60 Digital Camera
Canon d60 - Built-in flash will not pop up
There may be something obstructing it from popping open. Inspect the flash area carefully. You could remove the battery and put it back in to see if it corrects the problem. Also, check the flash settings in the menu to make sure that the flash is set to operate. If all of those fail then take the camera in for warranty repair. If the warranty has expired and nothing else works I would suggest getting an external flash for you camera. You will be amazed how much better your photos come out using an external flash. If you go that route then I would suggest going to a camera shop or department to make sure the flash will work for you before purchasing. If you just want a small flash a little better than the built-in, get the SB400. It's only around $125. The SB600 is much better, but will cost almost twice as much (but I think it's worth it).
They work beautifully in auto, but the SB600 will reach much farther and give you less red eye. Good Luck you have a great camera!
Nov 10, 2009 | Canon PowerShot EOS D60 Digital Camera
Sb-22 flash fires but d60 still opens the bilt in fash
I think you will need to upgrade to the 22s. It sounds like the newer model provides the D60 with a 'handshake' signal that the older 22 model does not have.
Sep 01, 2017 | Nikon Speedlight SB-22S TTL Flash
D60 not firing Paul Buff flashes by cord or wireless set up...
Here is the main support number.You can call them up and find a closest repair center in your location.
1 800 828-4040
If you are in USA you can find a service center from HERE
Goodluck..
Feb 29, 2008 | Canon PowerShot EOS D60 Digital Camera
Cameras Logo
164 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
