Car Audio & Video Logo
M
Matthew Curtis hurst Posted on Aug 05, 2017
How can I make my power acoustik DVD players touch screen to accept touch commands again?
5 Related Answers
Jeremiah Bohn
  • 12 Answers
  • Posted on Nov 22, 2007
SOURCE: WIRING
You need to order extra components in order to use the optional GPS function.. you can try checking circuit city or the Authorized Acoustik Suppliers for the products like the websites or you can check Ebay as someone might have the product
Anonymous
  • Posted on May 05, 2009
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Anonymous
  • 69 Answers
  • Posted on Aug 17, 2009
SOURCE: POWER ACOUSTIK PADVD-330 DVD Player issues.
if your pioneer radio has the light blue ipbus/changer plug on the back of the radio, you can use this adapter and turn on the <aux> in the menu where you set the clock.
http://cgi.ebay.com/Pioneer-IP-BUS-Aux-In-Input-Adapter-CD-RB10-for-iPod-a3_W0QQitemZ400030920263QQcmdZViewItem
Anonymous
  • Posted on Nov 28, 2009
SOURCE: my power acoustik 8960 touch screen does not
return it...it will start jamming when loading a disc and the fan will start to grind soon.  it is a bad unit..like all 3 I have HAD!!!!!
michael whitman
  • 102 Answers
  • Posted on Feb 07, 2010
SOURCE: how do you get the dvd player on my power acoustik
Hi all Car dvd players come with a emergency brake safety feature. They will only play video unless the emergency brake is applied. Although there is a code that can disable this feature . I purchased the code for mine on ebay for $10.00 Thank you for using Fixya.com
I have a power acoustik DVD player double din multimedia player, model # DVD2-654 what does the IR Blue Wire connect to
It may connect to another if receiver, if you have a second screen in the back of the vehicle you can control the unit from there.
Ptid 8970 it says something flips down to load dvd but for the life of me i cant figure it out
probaly the whole face folds down check all around the edges for a release if not send me a pic
How do I download pictures to my Power Acoustik PTID7002NR?
You can use a USB Flash drive or SD/MMC Card or an iPod to view files (Pictures,Videos,Music files..etc) in the player.Touch the icons [USB], [SD CARD], [IPOD] according to which device you are using.The corresponding modes are switched automatically by the player when it detects one of the above devices.The player will switch to [RADIO] mode automatically when the above devices are disconnected and if there is no Disc in the player or to the [DVD] mode if there is a Disc inserted.You can view the detailed description in the following link ( http://www.poweracoustik.com/pa2006/manual%20and%20catalog/source/PTID-7002NR.pdf ).Your valuable feedback would be appreciated.Good Luck.
2helpful
2helpful
I HAVE A POWER ACOUSTIK PTID-8970NRBT MY PROBLEM MY SCREENSAVER
Here is what I received from Power Acoustik for screensaver and desktop saving from SD card. "You need to have the remote in hand. Insert a memory stick or SD card that has the images you want to use. When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set of icons on the bottom. If you do not see an icon with a hand, press the arrows that are in a circle until you do. Once you see the hand, press it one time. It will save the image onto the internal memory. You will find the image in the screen tab in settings, under all the stock images."
My power acoustik 8960 touch screen does not respond
When my headlights come on my cd/dvd player screen turns blue
First of all your system is wired incorrectly. The person who wired it up is using either a power or remote signal from a light switch. That's NOT good. To correct find proper remote wire or you can use a power source that turns off when you turn ignition off and remove it from the Head light switch wires. Easy to find use a test light and check for power wire when ignition is on and No power when ignition is off. Good Luck contact if you need more help.Thanks for using FIX YA
4answers
Screensaver
This might be related to your question, read through the answers.
http://www.fixya.com/support/t126992-bypass_parking_brake_switch_in_order
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
