Baby Gear Logo
Susan Fine Posted on Aug 05, 2017
How do you remove the seat pad on graco fast action stroller
5 Related Answers
Anonymous
  • 281 Answers
  • Posted on Mar 02, 2008
SOURCE: installing graco carseat to valco tri mode stroller
http://www.gracobaby.com/catalog/what_is_latch.aspx
Hope this helped you
Anonymous
  • Posted on Apr 07, 2008
SOURCE: graco quatro wheel removal
i have the graco quattro tour sport, i put it together & noticed the swivel lock was missing! I have to take the wheel back tonight but i had already put it on the pram! after reading 'Adorough's' comment i had good look at the wheel to figure out how to get it off. 1) fold the pram up and stand it so the front wheels are up. 2) if you look round the back of the front wheel you should see a round 'pin' which is set back, you well need a pen or something pointy to press the pin in & pull the wheel! That worked for me.
Sarah
A
Anonymous
  • Posted on Jul 04, 2008
SOURCE: stroller pad cleaning
I took me a few hours, but I DID remove all the screws holding the cloth parts in place, and wash it all in the washing machine. I bought a used stroller/carset travel system, and was prepared to accept the loss in case I destroyed it in the wash, or couldn't get it back together correctly, but all went well, and I have a fresh, clean, "new to me" stroller and carseat.
Anonymous
  • 164 Answers
  • Posted on Sep 24, 2009
SOURCE: I am looking for a manual for a Graco stroller.
http://www.gracobaby.com/Instruction%20Manuals/archive/760-1-99.pdf
this link should take you to the manual.
umagamal
  • Posted on Mar 21, 2010
SOURCE: How do I remove seat cover on Graco Duoglider
there are tabs with screws holding them in place unscrew them and youll be able to slip the seat covers off.
Will a graco snugride car seat fit in the safety 1st double tandem stroller 01668sha?
Hi
Safety 1st do not produce adaptors for a Graco carseat to be fitted to the DuoDeal Tandem. This stroller chassis is not designed to be used with a carseat.
Duodeal Tandem Black Iron
ANy adjustments to be made to make a 4 month baby sit in Graco trilogic car seat ?
The Graco Quattro Tour travel system is one of the most popular styles, thanks to the big basket, one-hand fold and nice parent tray. There are some downsides to this travel system, though. Most notably, the Quattro Tour stroller is big, whether folded or unfolded, and it's heavy to boot. Whether you choose the regular version or the Graco Quattro Tour Deluxe travel system, the included infant car seat will be a winner. Paying extra for the Deluxe buys you a higher weight range on the car seat, which means a longer useful time, but again, adds weight to the whole system.
Graco Quattro Tour Travel System FeaturesThe foundation of the Graco Quattro Tour travel system is the Quattro Tour stroller, a full-size model with an aluminum frame. It also has one-hand folding, a multi-position reclining seat (including fully reclined for infants), a drop-down basket that can be accessed even while the seat is reclined, and a sunshade that rotates to cover nearly any angle you need. The parent tray has two cupholders. The front tray also has a cupholder for baby, and it swings open for easier access with bigger toddlers. The regular version of the Graco Quattro Tour travel system comes with a Graco SnugRide infant car seat, which holds babies up to 22 lbs. and less than 29 inches. The Quattro Tour Deluxe travel system comes with a SnugRide 32, which holds babies up to 32 lbs. and 32 inches. The difference in car seats is the only real difference between the regular and deluxe versions of this travel system.
What I Like About the Graco Quattro Tour Travel SystemOf the infant car seats that come with travel systems today, both the Graco SnugRide and the SnugRide 32 are good choices. These car seats are fairly easy to use, and they install pretty easily in most vehicles. Some of Graco's less expensive travel systems include a SnugRide with a back-adjust harness, but the car seats included with the Quattro Tour travel systems are a front-adjust version, which is much easier to use properly. You can use both SnugRide seats without their bases, as well, which is a plus. The Quattro Tour stroller feels sturdy out of the box and has a respectable 50 lb. weight limit. The steering is OK for a stroller of its size and price - better than average for full-size travel system strollers.
The one-hand fold on the Quattro Tour stroller works well. You just have to twist the middle of the handle and let gravity help the stroller fold itself. Since you have to deliberately twist the handle, though, there's not much chance of the stroller collapsing accidentally as there would be if you just needed to push a button or lever.
The basket on the Quattro Tour stroller is big enough to fit a large purse or diaper bag. It also has a nifty drop-down feature so you can get into the basket even if the stroller seat is fully reclined (a common problem on full-size strollers).
The canopy is good-sized and rotates around to cover almost any position needed. It's easy to put the seat into the fully upright position, and I like that it reclines all the way, in case you don't want to use the infant car seat in the stroller all the time.
What I Don't Like About The Graco Quattro Tour Travel SystemThe Quattro Tour stroller is heavy. At more than 26 lbs., you may get pretty tired, literally, of lifting this stroller in and out of your trunk after a few weeks. It's not small in terms of dimensions, either. When the stroller is open, it's just over 24 inches wide, which doesn't leave a lot of clearance for narrower doorways. Some parents complain that the wheels, which stick out a bit from the frame, are easily caught on things in stores or in other tight spaces. When the Quattro Tour stroller is folded, it's smaller, but not by a lot. It measures nearly a foot and a half thick and about two feet by three feet, which means it will pretty well fill the trunk of the smallest cars. Though the steering is better than most full-size, lower-priced travel system strollers, it's still not great. Once you've added a heavy toddler (or a bigger infant plus the infant car seat and a diaper bag), the steering can be a bit balky.
While the folding mechanism is sleek, unfolding the stroller is awkward. Similarly, while the seat is easy to move up, it's harder to recline.
The biggest problem with the Graco Quattro Tour stroller is durability. While this model seems to have a better track record than many of Graco's travel system strollers, there are still plenty of parents who complain that their Quattro Tour stroller is creaking and wobbly after a year or so of constant use. This is probably not a stroller that will last through multiple children, and you likely will not recoup much money by reselling it later on.
Should You Buy A Graco Quattro Tour Travel System?The Graco Quattro Tour travel system is not a bad choice if you're set on a travel system already. Many of its downsides won't be answered by choosing another brand or even another of Graco's travel systems. If you have realistic expectations about a travel system in general, you may be very happy with the Graco Quattro Tour. The infant car seat is the most important part of the travel system, and you can't go wrong with the front-adjust SnugRide or the SnugRide 32. You should try out the car seat in your vehicle before you buy the travel system, if at all possible, just to be sure it's a good fit. If the car seat doesn't fit your vehicle, that would be one reason to choose a different travel system.
In the whole of the stroller world, the Quattro Tour stroller wouldn't be one of my first choices since it's heavy, bulky whether folded or unfolded, and doesn't have a great track record for durability. However, as far as travel system strollers go, those things are to be expected. The Quattro Tour stroller is above average on a few convenience features, though, so combined with the decent car seat, it's among the better ready-made travel systems available.
1helpful
Can't open graco stroller
  • press the 2 red buttons
  • kick the spring
  • pull the seat out
  • press the look on top
  • push the seat out
  • aim only 10 years old i bought the graco stroller for my 2 dolls it a real stroller
3helpful
Install graco snugride to a graco stroller
Fitting your Graco Snug Ride infant seat into a Graco stroller is usually easy to do -- the exact instructions just depend on which stroller you have. Typically, all you have to do is fold the stroller's canopy back, recline the seat (if it reclines), and snap the car seat in (backwards -- facing the rear of the stroller). You can hear it lock in place when it's in correctly. Your stroller's manual will have specific instructions, and if you don't have the manual you can find it online.
Which Graco stroller do you have?
2answers
Adjusting seat in graco stroller
Our was an older model, but we just pushed it up and it clicked into place.
I just purchased a graco literider 320 stroller
Yes, you can get a matching car seat with base. try your local baby store, or look online for the travel system..once you find the travel system, you'll find the car seat.
Attaching baby carrier to rear seat of Graco duo stroller.
It should latch onto the tray/bar and then there should be two red clips on the stroller that you click/lock onto the foot area of the seat.
1helpful
Graco Glider Travel System Cloth Removal
Unfortunately graco seat covers do'nt come of you can try washing it outside with some shout a tide and hose it off it will look alot better.
Is this stroller compatible with other car seats such as Graco?
The manufacturer will not say that your Graco seat will fit in their stroller safely, however you could try your Graco in it and see if you feel safe that it will not fall out or be pulled out by your toddler.
Perego prefers to market their items to go with their car seats only, but we have found that the Graco seats fit nicely in most strollers. You should hook the stroller harness on to the lap belt routing path on your car seat to ensure safest travel in the stroller.
Good Luck! from Moms Just Know
Top Graco Baby Gear Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jay Finke
Jay Finke
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
