SOURCE: Can I use the cameleon or frog seat frame on a gecko chasis?
HIYA.... IVE HAD ALOT OF BUGGIES AND PRAMS... IVE ALSO MADE MANY BUGABOOS UP, JUST BY USING USED PARTS AND PIECING THEM TOGETHER.
ALL COMPONENTS FROG, CAMELEON AND GECKO FIT ONTO 1 AND ANOTHER. YOU COULD BUY A FROG SEAT FABRIC TRY EBAY FOR THE CHEAPER OPTION, THIS IS EXACTLY THE SAME SIZE. THE CAMELEON 1 WOULD ALSO FIT, AS IVE HAD A CAMELEON COVER ON A FROG SEAT FRAME AND IT FITTED JUST AS GOOD :)
HOPE THIS HELPS X
SOURCE: Are the instructions for fitting the footmuff for
Pretty much the same yes. All you need to do is to make sure that the footmuff is hooked over the back of the seat unit (easier to pop off the hood first). Then just loop the harness through the holes and this should fit fine.
I hope this helps.
SOURCE: will a frog seat frame fit on a cameleon chassis
Yes it will fit. the fabric seats are not interchangeable but everything else is. Currently I have Cam wheels on my frog chassis. As well as a cameleon canopy, and a fabric flease set on my frog seat.
SOURCE: Will the bugaboo chameleon seat/bassinet frame fit
The answer is yes, the chassis prongs are the same size and spacing. The size of the seat and bassinet are different so the fabric sets are not compatible.
SOURCE: My bugaboo cameleon seat tilt mechanism is stuck.
The large white buttons you push in are the problem. You can buy them. I found them at www.babycare.nl/spare-parts-bugaboo-cameleon-c-34_124_153.html
http://www.lilimay.com/buggies/bugaboo/spares.php
