Question about Jabra Computers & Internet
Reset my jabra bluetooth
Its not connected
SOURCE:
  • 8 Answers
SOURCE: connecting JABRA BLUETOOTH to MY SIDEKICK 3
Use your Bluetooth wireless headset or car speaker to make and receive calls: 1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible". 2. From your Sidekick, go to the Phone application. 3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.) 4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE . 5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name. 6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
Posted on Aug 25, 2007
TanyaAD138
  • 77 Answers
SOURCE: Reseting Jabra Bluetooth
Jabra headsets sometimes have a different way of being put into discovery mode. Most headsets just have you press and hold the big call button on it. Some jabra headsets require you to JUST hold down both volume buttons and some other jabra headsets require you to hold down ALL buttons on the headset to put it in discovery mode (or pairing mode as they sometimes call it)
Try of those combinations ... The light will stay solid when it's in discovery mode... Once the light is solid THEN have the EnV search for headsets.
hope this helps
Posted on Dec 22, 2007
SOURCE: jabra bluetooth headset
  1. Start with your Bluetooth headset powered off
  2. Hold down the Answer/End key for 6 seconds. Light will turn solid blue.
  3. Release Answer/End key, Light will remain unchanged.
  4. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset.
Posted on Oct 23, 2008
rockfixya
  • 679 Answers
SOURCE: connect jabra to blackberry
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT150 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
SOURCE: The Jabra A210 keeps dropping the connection between the devices.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
Posted on May 05, 2009
Jabra hfs001 is not connecting with my Samsung Wireless phone
MY JABRA CONNECTS BUT I HAVE NO VOLUME I HAVE A
T-MOBILE PHONE. I RESET THE JABRA I TURN UP THE VOLUME ON MY PHONE NOTHING
Sep 27, 2010 | Jabra Bluetooth Car Kit with Night Driving...
Jabra HFS001 I can't connect with my iphone 4? please any help?
MY JABRA CONNECTS BUT NO VOLUME TRIED TURNING UP PHONE TRIED RESETTING JABRA ALSO
Aug 02, 2010 | Jabra Bluetooth Car Kit with Night Driving...
Can not find my booklet to get the code to reset my bluetooth
password for connecting the Jabra bluetooth to the phone is 0000.
Nov 16, 2009 | Jabra BT125 Headset
Mar 13, 2009 | LG Jabra A210 Bluetooth Adapter for...
Initialy i had used my jabra bt350 with sony ericson but now it is not getting paired with my present mobile
dude first of all you have to reset the passcode of your jebra bt350 then connect it from your parents mobile.
how to reset----
Press settings/connections/bluetooth/check both boxes; turn on, and make discoverable/click devices tab/turn the jabra off/then hold the ear button till the blue light is solid (not blinking)/click new partnership on the phone/click 0000 for the passcode. it should hook up.
Mar 06, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
How to use Jabra BT5010 with 2 mobile phones
Be careful of the earhook Jabra does not offer a replacement in the BT5010
Dec 07, 2007 | Jabra BT350 Bluetooth Headset Headset
Computers & Internet Logo
103 people viewed this question
Top Jabra Computers & Internet Experts
 Mike M
Mike M
RudeRude
Andrew Taylor
Andrew Taylor
Are you a Jabra Computer and Internet Expert? Answer questions, earn points and help others
