Computers & Internet Logo
A
Antoinette Posted on Aug 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there lotus 123 software that is compatible with Windows 10? I have lotus files on my computer but cannot access it.
Bill Boyd
Level 3:
Top Expert:
  • Lotus Master 53,816 Answers
  • Posted on Aug 04, 2017
Bill Boyd
Lotus Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11934289
Points
172802
Right click on lotus 123 and and in properties click on the compatible tab
click in the square and high light the win 10 operating system
If win 10 is not there , it is not compatible
1 Related Answer
Anonymous
  • 1082 Answers
  • Posted on Aug 12, 2010
SOURCE: problems opening lotus 123 files, very slow
I have all my Lotus files on a server and am not experiencing this problem. Did you install the desktop version or the network version. Mine is desktop and I get my files off the server. Works well.
Lotus 123 problems
Microsoft Excel should open your old Lotus files.
Go to File > Open > Select Files of type: Lotus (*.wk?) and select your Lotus file.
Alternatively you could install and use OpenOffice spreadsheet or LibreOffice Calc and open your Lotus files.
Will lotus 123 load from a cd on windows 8
you have to create a batch file to run Lotus 1-2-3, and (so far as I can tell) you have to run the program from your root drive, because the program makes its calls TO the root drive. Here's the batch program you create in Notepad or other plain-text editor:
cd\
cd\lotus
123.exe
cd\
exit
* Delete the 'exit' if you want the window to stay open as a DOS window, after you're done with the program. Save the file with a '.bat' extension. (Note: unlike XP, you can close the window with your mouse, afterwards.)
* After creating that file, you have to right click on the file name, select 'Properties (in Win8, Vista, XP) and do some more tweaking. The Properties dialogue box SHOULD show the following tabs: General, Shortcut, Options, Font, Layout, Colors, Compatibility. Each of these needs editing.
GENERAL tab: select Normal Window or even Maximized (though it won't actually maximize). Also in Win8, click on Advanced, and 'Run as administrator'.
OPTIONS tab: select Large cursor. You can always change it, but since the program really won't run fullscreen, you'll want the cursor to be oversized, since the window will be smaller and will shrink everything in it.
FONT tab: this is what Windows uses to select the screen size, despite all the other settings (which you also still need to set). In Win7, you have three types of fonts to set. Click on the 'Bold' option, as that makes the text easier to read.
For True Type 'Consolas' font (which results in a more square window), pick a font size between 18 and 24. More than that will be bigger than your entire monitor screen, when you actually run the program (looks are deceiving, you have to test the results with trial and error).
For True Type Lucida Console font, use the same 18-24 font size range, but the screen will be much shallower and wider, so you can afford to decrease font size to 18-20. 28 is really too wide, on a widescreen monitor (1366x768 pixels). But maybe you'll like it, or your monitor will accommodate that size. Mine wouldn't.
For Raster fonts, 12 x 16 is the optimal setting. ON some (i.e., Dell Ultrasharp) monitors, Raster fonts look best. On my Toshiba 19L4200U TV monitor, the Lucida Consule setting is clearest.
LAYOUT tab: Pick a window size width no greater than 85, and height no greater than 38. Then test to see if it's too big. If yes, you'll also need to decrease font size, as well as the Layout size, here. Experiment, because you can't gauge the right mix of window and font size, just by the diagrams in the dialogue box.
COLORS tab: Lotus 1-2-3 makes hardware calls on the screen, so whatever you put in this tab, it will ignore. But other DOS programs might 'obey' the colors you set here. If you remember the old Norton Utilities days of setting Mode, etc., that's what this is.
COMPATIBILITY tab: You can't set resolution to override at 640x480. The setting is either ignored, or your monitor will freak out. For Lotus 1-2-3, in Win 8 I didn't need to turn on the 'compatibility mode'. It made no difference in the results. (You don't need it in XP, either.)
* Finally, you have to find the program itself, then right-click on the program name and edit its Properties. Here, that program is 123.exe, and it has to be in your root directory. (All the program files Lotus will use, must be there; at least one wk1 file must be in C:\123 at startup. I'm sure this can be tweaked, but I'm using the default Lotus program settings for a typical installation.)
I have ancient lotus 123, approach, amipro and need to fit them into the new lotus smartwuite. How
well an ancient is fine what is not fine is that xp you installed is most likely not compatible with older versions, which were 3.x and early xp ok
time for an upgrade methinks.
Problems opening lotus 123 files, very slow
1helpful
Info on Zip Disk completely over ridden. Lotus 123 being used.
It's called a disk cache, the cache wasn't flushed before you swapped the disks. I remember Lotus 1-2-3, I first used it in 1987 on a Compaq portable. But I haven't used a Zip disk in 10 years, that's totally obsolete technology.
Good thing you have hard copies.
Cannot open program. Error message "Lotus 123 Application has encountered a problem and needs to close". Worked fine last week.
Are you running Lotus Notes as well? There is a known compatibility issue and a patch for this.
Have you upgraded or installed new software recently ? Version 9.5 is not the latest version and has some issues with newer software.
My lotus file is corrupt no run and run time error
Corrupted lotus file may be repaired with the help of nsf file recovery tool
Tool http://www.recoverytoolbox.com/lotusnotes.html will effectively aid you
Top Lotus Computers & Internet Experts
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Lotus Computer and Internet Expert? Answer questions, earn points and help others
