Basement smells musty, fan won't stay on continuous
Barbara, are you running the unit in a continuous mode (i.e Using a hose to drain the unit)? Or is the water draining into the water collection bucket?
If you are not using a hose for continual drainage, the fan will not run constantly. It requires that, for continual operation.
Also, you may have the humidity extraction level set to high. Lower it to 35%. Also, remove and check the air intake filter, as it may need cleaning.
Dehumidifiers that are not Low Temp models have a difficult time operating in basement applications. Because the air temp at floor level is colder than at shoulder level. At temperatures between 40 & 60 degree F, regular dehumidifiers struggle to keep up. Raising it up off the flow on to a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water can really help.
I hope this was of assistance and thanks for choosing FixYa.
