Lands Phones Logo
Sunny Dobson Posted on Aug 03, 2017
How do I program one touch dealing into memory on a GE phone model TC29568GE1-A
How do I program a speed-dial number in a GE MultiMemory SpeakerPhone Model 29322GE1-A
The instructions are in the "Memory" section starting on the fourth column of the manual at
http://www.home-electronics.net/USER-GUIDES/29322_DOM_ES_CD_IB.pdf
Programming memory
Click below to download manual;
Download User Manuals
hope this may help;
regards,
VOTIT
Want to program telephone #s for one touch dileing
The memory instructions are in the fourth column of the first page of the manual at
http://www.home-electronics.net/ge/pc/IB/29369GE1_IB.pdf
4helpful
GE Phone, corded model 29318GE1-A. How do you
Go to retrevo.com and search for your phones user manual. You can find manuals for almost everything there.
1helpful
2answers
Need help programming autodial feature on my ge-27923-ge cordless phone
how do you change GE Model 27923 2.4 GHz cordless phone from pulse dial to touch phone dial? I lost my instruction manual Thanks
Uniden Model EXP7900 How do I program button m1
One-Touch Dialing
Your phone is equipped with three .One-Touch Priority. keys for
instant dialing (m1, m2, and m3). You cannot store phone
numbers directly into m1, m2, andm3. They are only used
to dial phone numbers stored into memory locations 1, 2, and 3
on the keypad.
1. To instantly dial phone numbers stored in memory locations
1, 2, or 3, simply press m1, m2, or m3. (There is no need to
press talk, the phone will automatically dial.)
2. If no phone number was stored in memory locations 1, 2, or 3
on the keypad, pressing m1, m2, or m3 will do nothing.
I hope this helps.
Rollin CBs
Dean
1helpful
I lost my manual and I need to know how to program a name and number
I just programmed my phone of the same exact model, I was searching on Google for a solution so I thought I'd share it with you. GE does not have a manual on their website for that model, but I went to the manual of a similar model (27940DC1) that has a manual, http://www.home-electronics.net/ge/pc/IB/27940DC1_IB.pdf . The procedure is exactly the same. I was able to program my new voicemail number in with no problem. Good luck!
Bob
Feb 12, 2008 • Cell Phones
Programming memory
How do you Program a CT-P720 using the Memory
6helpful
4answers
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
