SOURCE: Can't send pictures!!
First, try performing a hard reset: remove the battery from the BlackBerry while it is still powered on. Leave it out for 30 seconds, then reinsert.
If that doesn't work you might try re-registering on the network. Go to Options > Advanced Options > Host Routing Table. Highlight a table, press the menu key, then select Register now.
Also, make sure that Browser Push is enabled. Go to Options > Advanced Options > Browser Push and make sure Enable Push, Enable MDS Push and Enable WAP Push are enabled.
SOURCE: Cannot Send Email to Anyone!
Also, it looks like Yahoo are now checking the verification of your account before you can use the SMTP service.
You need to do this..
http://help.yahoo.com/l/us/yahoo/mail/original/manage/sendfrom-07.html
SOURCE: Yahoo email going to wrong email address
i've had this problem also, the problem lies within yahoo's mail server your best option is to email their customer support team with your problem.
SOURCE: Emails not reaching destination although they are in 'sent box'
This can be due to your destination server's security settings that are set to reject incoming Yahoo emails, that were largely used by spammers in the past years.
What you can do is call the person you are trying to reach by email, and ask him if there was any security settings set by his company or ISP.
Frequently companies are using "blacklists" in order to block junk mail. You are then in a "false positive" situation that is hard to solve. Try to send from another email adress to see if that still happens.
Hope this helps
SOURCE: Why are some emails rejected?
This is possibly because the person leaving the comment is spamming and so uses a false/non-existant address.
To ensure the user has a valid address, set the comments to require the person to register on the site (validate their e-mail address), then login and leave a comment.
