SOURCE: is rx-v659 compatible with new ipod dock YDS-11
Both docks will work with your receiver.
Dank
SOURCE: area of rectangle having length 1 fit and width 3
Hi amita_mediai
Do this:
1*3*20
Explanation
Multiply the length and the width. This gives the area in sq ft. Multiply this with 20. This will be the cost in rs.
Good luck
luciana44
SOURCE: I have a Yamaha RX-V465
Yes, it is compatible.
http://usa.yamaha.com/products/audio-visual/accessories/yds-12_black__u/?mode=model
It has 2 modes of operation. For RX-V465 you need to select mode B. In this mode it is compatible with YDS-11, which is supported for RX-V465. But iPhone is not officially supported in this mode. But I have found on Yamaha website FAQ, where they claim that iPhone switched to Airplane mode worked well.
http://faq.yamaha.com/us/en/article/audio-visual/accessories/yds-12_black__u/4742/4061
Did you find a solution for this ?
You haven't received any help because the request looks a lot like a homework assignment and a lot of people are unwilling to do that.
I have some suggestions:
1) You should make sure that you have a working copy of Java. Start at the Java Tutorial: http://docs.oracle.com/javase/tutorial/java/TOC.html
If you do not have a working Java on your machine, follow the link at the top right of that screen to 'Download JDK'. That is the set of programming tools you need to use to compile and run programs.
The Installation Instructions will tell you everything you wish to know. I suggest that you use: http://notepad-plus-plus.org/ to type in programs.
Good luck. Post more on the problem page for more help.
