The unit is brand new. When I try to adjust the units water flow dail up it shuts the unit off. Gas pressure is good. All components are brand new. The unit will only operate with gas and water flow dials at the lowest settings. The shower continues to get hotter due to low water flow through the unit. When you turn the shower colder it will eventually shut down the hot water unit. Pressure and volume of water to the unit is excellent. If I also open another hot water valve like the bathroom sink this does not occur. Gas burner can be turned up all the way with no issues other than the unit overheats too quickly.
SOURCE: On demand, tank less water heater
THE WATER IS RECIRCULATING IN THE UNIT. MAYBE CAUSED BY THE ACID. TRY INSTALLING A BACK FLOW PREVENTER
SOURCE: tp valve opening and dumping water
Certain water heaters can only handle so much pressure from the main line. There is a pressure controller between your water meter and you house, it's called a pressure regulator. You need to call a plumber to check and see if it needs to be adjusted or even replaced.
SOURCE: Tankless Paloma NG hot water heater shuts down
have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
SOURCE: I have a tankles hot water heater. The problem is
If this ia a Chronomite Tankless Electric water heater we suggest you call our technical service department at 800/447-4962 for assistance.
SOURCE: burner lights but will not shut off. then pressure
i am having the same problem with mine changed the pressure relief valve and the ECO \ TSTAT but still gets extremely hot can't even touch the water what else could it be
That is the temperature pressure relive valve (TPV) . It is either foiled with some thing or going off because of a pressure or temperature problem. If it is leaking continuously it is foiled and needs cleaning. If I where there I would replace it with new.
