SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
SOURCE: contact list says empty but reads 166 contacts
if u have both buisness and personnal as active filters it will say no address, Just go back into filters and remove both of them and you will get you contacts back
SOURCE: Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
SOURCE: Avaya 6416D+M, rings half ring, then goes straight to voice mail
you might status the phone to make sure that send all calls somehow is not on. :)
SOURCE: i cannot hear phone ring on avaya awh75n headset
Is the phones ringer turned up? It needs to be loud enough to make the ring detector ring.....
