Hi. Registers don't beep when they need the battery changed. It's best to find out what is causing the beep. I don't work with the CS700 but both manuals are on the net:
https://the-checkout-tech.com/estore/catalog/advanced_search_result.php?keywords=CS700&search_in_description=1&x=0&y=0
Hope this helps
SOURCE: I have a problem with cash button on TE 2400 cash register.
Hi.
Try this:
Turn key to program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
Mark
SOURCE: How to program the Sharp XE-A12 cash register
here is a link to the software.
there is not enough space here to type instructions, its 90 pages long.
you will need a sd card or usb cable to connect to your puter.
http://www.sharp.ca/downloads/default2.asp
SOURCE: Wanted sigma cr 2000 cash register manual
hi would it be possibe to explain how to do an end of day read on one of these tills , we have recently taken on a business with one of these tills in it but cannot locate a manual ........... and we havent a clue how to use it .
SOURCE: Our sharp ER-A310 cash register
E32 is usually an indication that the server or cashier has not been signed on. To resolve; 1) Press the clear button. Doing this will take you back to all zeros in the display 2) Enter the number 1 and then press the green or blue button which is labeled CASH, at this point you till have 01 in the display, indicating cashier 1 has been sign on.
Testimonial: "Fixed the problem thanx"
