SOURCE: resetting combination bike lock
Try rotating locking device 180 degrees and hold it down and set combo to 0000, then let up on locking bar. That should clear the old combo. To reset, rotate the device 180 degrees and hold down while inserting your new 4 digit code and then release it.
SOURCE: Have a wordlock and I have forgotten the word I made up what can I do to reset the lock?
Well, short of help from WordLock, you might try an old safe cracking method. Put tension on the removable plug and slowly turn each wheel. You 'might' feel/hear the slot inside the wheel catching on the plug. It might not be felt on the first wheel you try; if you don't feel anything at all, move to the next wheel. Then the next, etc. I think one of those wheels will 'tick'. Leave that wheel there and move on to one of the other three. Repeat until they all line up and 'there you are'. Mind, this may not work if everything inside is super polished; I'm counting on some rough edges to catch on each other. Good luck.
