We are using this spark plug and want to use the fine wire plug. What does the champion RHB37E cross to for fine wire.
SOURCE: Diagram for spark plug wires
Firing order 1-6-5-4-3-2
| 2 4 6 |
front | |
| | 6 5 ||
of | | 1 4 ||
| | 2 3 ||
vehicle | |
| 1 3 5 |
Distributor rotates clockwise
SOURCE: spark plug wiring diagram
3.9L V6 Engine. Engine Firing Order: 1-6-5-4-3-2. Distributor Rotation: Clockwise.............did i guess the right motor? let me know/rate me
SOURCE: Spark Plug for Briggs & Stratton Engine
you'll need a champion J19LM [or RJ19LM, same plug except the RJ is a resistor plug]
SOURCE: I replaced my spark plug wires on my 1996 chevy
Since you didn't state whether it is a V6 or V8, I'll give you both.
V6 -4.3Liter
Firing Order is 1-6-5-4-3-2
Distributor rotor turns Clockwise
Number 1 spark plug tower on distributor cap, faces the front of the engine.
->Drivers side, spark plug order in engine, starting from the Front going back:
1-3-5
->Passenger side, spark plug order in engine,
2-4-6
If it's Electronic, the distributor cap has a Left side, (Drivers side), and a Right side, (Passenger side)
Starting from the Front, going back on the Left side,
3-1-5
Starting from the Front going back on the Right side,
2-4-6
V8-5.0, 5.7, and 7.4Liter
Firing Order is 1-8-4-3-6-5-7-2
faces Front, towards the Drivers side.
Electronic distributor cap has two sides. Drivers, (Left), side and Passenger, (Right), side.
Starting from Front going back on Drivers side,
1-7-3-5
Starting from Front going back on Passenger side,
8-2-4-6
Spark plug order in engine, starting from Front going back, Drivers side:
1-3-5-7
Spark plug order in engine, starting from Front going back, Passenger side:
2-4-6-8
SOURCE: someone crossed spark plug wires i need fireing
It is stamped on the top of the engine, in the head. It is usually pretty easy to find, and you wont have to remove any pieces to see it.
Testimonial: "ty "
