SOURCE: changing the sanding pads
You use a 1/2 inch socket wrench to remove the nut at the top of the spindle shaft, slide the old sanding sleeve off and the new one on. Replace the nut. You may also have to insert a different size table insert if you are changing the sleeve size.
Instruction manual is available free at:
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/a20932,sa350k.pdf
