Ice Cream Makers Logo
T
Tomas Lagunzad Posted on Aug 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT IT MEANS R-HPR THERMAL FAIL FOR TAYLOR ICE CREAM MACHINE MODEL C713
www.softserveparts.com
Level 2:
Scholar:
New Friend:
  • Taylor Expert 35 Answers
  • Posted on Aug 01, 2017
Taylor Expert
Level 2:
Scholar:
New Friend:
Answers
35
Questions
0
Helped
75359
Points
271
That code means the right side hopper thermistor probe has failed. That is the sensor that reads the temperature of product in the mix hopper.
This is the part you need:
http://www.softserveparts.com/i-26471492-thermistor-probe-c712-c713-barrel-stanbye-probe.html
If you order it from us, I would be happy to put a technician on the phone to help you install it yourself.
WHAT IT MEANS R-HPR THERMAL FAIL FOR TAYLOR ICE CR - 038061_thermister_probe-cljpjucqyad4b2ehvf5zpumf-2-0.jpg
5 Related Answers
Commercial Appliance Service, Inc.
  • 81 Answers
  • Posted on May 02, 2009
SOURCE: TAYLOR 632-33 ICE CREAM MAKER
If you are wiring a Taylor machine to three phase power and you have a "wild leg" or "high leg" you must place the high voltage leg on L3. This will keep the higher voltage out of the control circuits of the machine. To clarify what a high leg is, it is created in three phase applications where a certain type of transformer is used. It creates two normal power legs, 110-120 and one leg that is only useful with another leg of power. If measured to nuetral or ground a wild leg will measure considerebly higher than the other legs. Hope this is helpful
Anonymous
  • Posted on Feb 22, 2010
SOURCE: Spares for Taylor 8756 ice cream machine
looking for 777 741 770 beater blade
Anonymous
  • Posted on Nov 19, 2010
SOURCE: I have a Taylor PH71-58 ice cream machine could
access code is 8333
Testimonial: "Thank you for the access code to my ice cream machine, this will help me a great deal."
Anonymous
  • 4 Answers
  • Posted on Feb 21, 2012
SOURCE: taylor soft serve ice cream machine model #y754-27
If you need parts go to softserveparts.com tell them shaun sent you.
Anonymous
  • 107 Answers
  • Posted on Apr 19, 2012
SOURCE: beater overload
if your mix level is low ice cream will freeze in cylinder which in turn will over amp the beater and cause it to trip. Check mix pump and make sure all orings are good.If mix isnt leaking out make sure it is pumping in.
I have to keep pushing the reset button to freeze ice cream
https://www.taylor-company.com/assets/pdfs/downloadables/0336_338_339op0.pdf
www.fixya.com/support/t12152755-beater_overload
Mar 24, 2012 - If your mix level is low ice cream will freeze in cylinder which in turn will ... are never placed on hold and get to talk to real repairmen in the US. How to fix beater overload on taylor C713
Dec 12, 2013
SOLVED: My Taylor c713 is on "R Beater Overload ...
Oct 12, 2013
Taylor c713 reset button
Mar 31, 2013
beater overload taylor Questions & Answers (with ...
Jan 26, 2010
More results from www.fixya.com
Why would a Taylor C713 be making darker and icier soft serve than normal?
I generally see this happen when the air to mix ratio is off. This generally happens overnight when the machine is in standby someone forgets to flip the feed tubes so that no more product is drawn into the freezing cylinder.
Your viscosity could also be set too low.
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
I just replaced the two beater drive motors on my Taylor c713 ice Cream machine now when I power up communication failure comes up
Every time I have seen that, it is just the USB cable on the mother board in the back of the machine.
1. Shut off and disconnect the machine from power
2. Remove the rear panel
3. Remove the electrical panel cover
4. Find the USB cable on the bottom of the board all the way to your right.
My C713 water cooled yogurt machine keeps locking and only works when cleaned but only for a few hours then it locks again. Does anyone know why?
The temperature of the product is too high. If the product either in the cylinders or the hopper goes above safe temperature for too long the freezer will lock until the product is removed and the unit is properly cleaned. I would guess it's the hopper temperature because I think you would notice if the product that's dispensed is above 40 degrees. Soft Serve Parts C713
Why does machine have 2 cords and 2 cord caps
Because of the amount of energy it requires. It was set up for a non 220V location. Plug each cord set into a different circuit.
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
3helpful
4helpful
3answers
Beater overload
Top Taylor Ice Cream Makers Experts
vince
john h
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
