SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
SOURCE: anti flood device needing reset
pull the dishwasher out and tilt it forward to reset..worked on my electrolux.
SOURCE: Reset anti flood device in dishwasher Beko DWD 4310 S
**** the water out of the pan below the dishwasher, there is a float in the pan if you have a leak and the pan fills with water
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
SOURCE: Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
