SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
SOURCE: upper thread not being picked up by bobin thread
Is the under thread getting all bunched up?
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
SOURCE: needle won't pick up bobbin thread tried cleaning
did you clean the bottom bobbin area thoroughly? Remove the cover plate and bobbin reel, look for debris. Any left over cotton will cause problems, after you clean it spray some wd-40 on all moving parts.
Thanks
Adam
please leave me some feedback
SOURCE: Top thread will not pick up the bobbin thread.
(1) Check the needle or replace with a new one. A needle has a groove in one side of it and that is the side that the thread enters the needle. Some thread from the side and some from the front.
(2) Before sewing, manually turn the wheel to make the needle go down while holding the needle thread with your left hand. When the bottom thread pulls up, pull both threads toward the back of the machine before sewing.
(3) Make sure your pressure foot has been lowered. Sounds silly, but if you lift is high it might just look like it is engaged.
(4) Try it on two ply fabric first and try both a straight stitch and a zig zag and see if you have problems with both.
(5) Make sure your thread is really machine thread and not hand sewing thread.
(6) Make sure the bobbin thread is feeding off the bobbin spool in the right direction.
(7) Anything other than these is probably a tension problem or a timing problem.
