Question about Yes Televison & Video
I have a changhong tv model led19d2200dv which i bought 3 months ago but now my remote wont work at all, and yes it has new batteries, it was display model and im wondering if that caused it to stop?
I have a Changhong CHL2643A TV, the remote control won't work but will work on another Changhong TV The TV receiver must not work is that right
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
Nov 08, 2016 | Televison & Video
Changhong tv does not respond to remote control, again. This happened 8 months ago, and for some reason it started working. I have no idea how it fixed itself, but I need it to fix itself again!
Sounds like the infrared sensor inside the TV is faulty. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 06, 2016 | Televison & Video
My original remote with this model stopped working several months ago.I bought a phillips universal remote and that worked fine for several months and that stopped working.I bought a new Phillips...
The first possibility is that the new remote control is a dud out of the box. It can happen. Another possibility is that the remote sensor in the TV has failed. Then the remote is transmitting, but it's not being picked up by the TV. (The lights are on but there's nobody home.) If you can, return the new remote to the store and exchange it. Then, if the set still doesn't respond, you'll need to replace the remote sensor.
Jan 02, 2011 | Sylvania 4819LT 19" TV
Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Apr 18, 2009 | Sylvania SRT2319 TV
Bought a fairly used 2003 HDTV 4 months ago, Didnt come with remote but got a Universal I used that worked, my friend took the batteries out for a while for something else, we put the batteries back in...
Hard to say what the code is without knowing the model number of the remote and the brand of TV.
RCA's website has a remote code finder you can use.
Dec 17, 2008 | RCA Universal Remote 3 Device Remote...
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
Remote problem
I understand Ilo's are made by Tatung. You may try 0055 or 0003. I haven't confirmed this, but it's worth a try. http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
Aug 24, 2007 | iLO 2600 Television
Televison & Video Logo
49 people viewed this question
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
