Here's a simple way to install Mobdro on Firestick. All you need to do is download the Downloader app on Firestick and then use it to install Mobdro on the device.
https://www.juststream.io/how-to-install-mobdro-on-firestick/
Download Mobdro on Firestick with three different methods.
1. AdbLink
2. ES Explorer (Recommend)
3. Paradox
It is very easy methods but using the app file.
Please follow the guide with screenshots buy here . How to Install Mobdro on Firestick 100 Working Method in 2017
Make sure you device connected to Internet while install.
If you are referring to your router, is it from your Internet service provider (ISP)? If so, you can call them.
If not from them and you bought it from a retail outlet, you can...
1. open your web browser like IExplorer.
2. in the address bar (Where you type in the URL (web address like www.?) type your router's IP address example:192.168.1.1
and enter the user name and password to access the router. Or
3. Press and hold the reset button on the router and start from scratch using the router's setup wizzard making a new password.
4. Using a button located on your router use the router to give permission to allow the device to access it.
NOTE: you can go on D-LINK's web site and download the users manual and/or software for your router.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/ron_a476a70a75690d24
SOURCE: how do i upgrade soft wear to my amazon fire tv stick
URL for software updates and instructions
Should also be in your user's manual.
http://www.amazon.com/gp/help/customer/display.html/ref=ya_kindle_sb_swupdates?nodeId=200529680
Ron Harvey
SOURCE: When I connect my Amazon fire stick to my tv it knocks as sound off on my tv how do I solve this
From the Home screen, go to Settings > Display & Sounds > Dolby Digital Output and make sure Dolby Digital Plus is set to OFF.
SOURCE: does anyone know if the amazon fire tv stick can be controlled by a universal remote control
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
