SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
SOURCE: Singer Sewing machine
I found the same numbers on my Singer, but learned that the 13608M is not the serial number. I finally found it on the bottom of the machine. It typically begins with either a single or double letter. You can find the Serial No. and Year of Issue at http://www.singerco.com/support/serial_numbers.html. You can also order a replacement manual. Another helpful site might be http://www.ismacs.net/Singer/singerdates.html.
Good luck.
SOURCE: need instruction manual for singer sewing machine mod.57825C
Visit us at www.ifixmachine.com
SOURCE: How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
