Tension seems wrong as looping in stitching.
Loop and nesting on the bottom side is usually the result of top thread tension too low or uneven feeding of top thread. It can also be caused by lint or debris in the shuttle (bobbin) area. Be sure needle is not barbed at its tip. I didn't find a manual (free) for this model but pictures show it has a vertical spool pin so not a spool cap issue.
Test tension of top thread.
With needle up, presser foot up, and tension select = 4, thread machine. Then make a long slow steady pull of top thread. The thread should advance smoothly through needle eye without snagging from top spool. Now lower foot and make another long slow steady pull of thread. Again it should advance smoothly through the needle eye. Note difference no tension (foot up) and selected tension (foot down). If no difference in foot up/down tension then something wrong with the tension selector or not threaded properly, consult machine manual.
Test bottom thread tension.
You can do a similar test of bobbin thread tension. Make a slow steady pull of bobbin thread. It should advance smoothly from bobbin with tension similar to top thread with tension =4. If bobbin tension is similar to top thread foot up, then likely bobbin thread has escaped bobbin tension spring... reload bobbin per machine instructions.
https://www.youtube.com/watch?v=O7N4XaIV6ms
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point and then tweak it so the top and bobbin threads meet in the middle of the fabric.
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
I'm **t sure what you mean by freehand stitching........do you get a good even stitch with zig zag, this is the most important first test ?
Ensure that all is clean and free of lint jams....**w for tension troubleshooting .......
This solution is for tension problems...if you can**t form any sort of stitch, the issue is quite different, so please let me k**w if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "k**tting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and **t to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do **t gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would **t recommend fiddling with bobbin tension without good reason, it may end up with missing small *****s and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (**t soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is ** lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension ***** in the middle of the metalwork....
...the other ***** at one end is holding it all together, so beware....it is **t a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's ** trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension ***** very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it can**t be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....** case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (a**ther reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
