SOURCE: I have a farmall super a and I was mowing when it
First check and see if the rotor is broke if not check your points,you can file them But i would put a new set in with a condensor,I hope this helps you and thanks
SOURCE: Which cylinder is #1 on a Farmall Super
The radiator. All in line engines always have the #1 cyl closest to the harmonic balancer / belt pulley.
SOURCE: NEED TO KNOW HOW TO TIGHTING STEERING ON 140 tractor
if all tie rods are tight the steering box has a philips screw with a jam nut loose nut turn screw in until it stops, back out a little tighten jam nut. that takes slack out of worm gear. hope this helps
