SOURCE: setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
SOURCE: 2006 buick la crosse when i
The noise from the power steering unit can be from wear,the only way to eliminate the noise,is to replace the unit.
SOURCE: How do you get the
A code reader is needed, often a lube shop will pull the codes for free. You need that piece to know how to proceed.
SOURCE: where is the power steering fluid located on a
If you have the 3.6L it is at the back of the engine compartment, just to the left of centre, and just to the left of the "big cover".
If you have the 3.8L it is at the back of the engine compartment, near the window, on the centre-left, immediately below the alternator.
