SOURCE: Error 16
Dear Rashid,
I understand that this errors occurs in POST mode. You can always refer to service manual or troubleshooting guide of your machine upon purchase especially it displays error code. However not all error codes are not servicable for ordinary users due to risk. To give you an idea in solving the problem; present this error code to authorized service center and offer them to purchase the defective parts regarding this error, or you can troubleshoot by detaching or removing running parts one at a time. We'll see if the error changes. Contact me if there are progress, I can help you pin-point the problem somehow I can resell parts soonest with this type of printers.
Best regards,
Rosener Guyano
SOURCE: motherboard BIOS softwere for update
The process of upgrading the BIOS on a computer is also
called "FLASHING" the BIOS.
On very old computers (486 and older) the BIOS may be
permanently programmed into read-only memory chips,
which are not flash-able, although it may be possible to
replace the chips, or re-program them using special
equipment by a qualified technician.
On virtual all modern computers, the BIOS can be updated
using new data and a special FLASH program available via
download from the manufacturer.
This is a very dangerous procedure that can destroy the
motherboard if performed incorrectly, and should not be
performed unless absolutely necessary, such as when
you computer or software will not run properly without it.
Most mother board manufacturer's (for example Asus) offer
software patches and downloads on their web site, as well
as BIOS upgrades.
Note that the BIOS is 100% board specific, installing the wrong
BIOS can permanently destroy *********** board, so make sure
that you download the correct one for your board.
Once you have the downloaded the BIOS upgrade, there are 3
possibilities:
1) The downloaded file is self-installing, either from Windows,
or it creates a boot-able diskette, which in turn contains all
the files needed to update (FLASH) the BIOS.
2) The BIOS comes with a a separate installer (.exe) which
either runs from Windows or via a boot-able diskette.
3) The existing BIOS has a "built-in" flash utility, accessable
through the BIOS settings. This utility runs at a very low
level without any operating system to self-update the BIOS
from your download binary file, located on the hard drive or
on a diskette.
This is by far the best and safest way to do the job, but only
if your motherboard and (existing BIOS) has that capability.
In any event, the first step is to visit the manufacturer's WEB
site, then go to SUPPORT or DOWNLOADS.
Find the exact model and version number of you motherboard
in the manufacturer's list, and download the latest BIOS
update, and any installation (or flashing) utilities that come
with it.
1) Follow the manufacturer's instruction exactly !!!!
2) Do not turn off the computer until the BIOS update is
complete, and you are instructed to do so !!!
N.B.
The computer BIOS is the lowest level program on your PC,
without which the computer CANNOT read the disk drives or
perform the lowest necessary functions.
If the BIOS is damaged, or
If the wrong upgrade is installed, or
If the upgrade is performed incorrectly, or
If the upgrade is interrupted or crashes before finishing,
the computer may become unable to repair itself, and
the mother-board may become permanently unusable.
(This depends on the actual mother-board and BIOS design,
and on the damage done by the failed installation)
Good luck,
Please rate my answers,
Martin
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
