SOURCE: Removal of factory seat on Yamaha Royal star 1300
Hi, It opens with your key on the right side as looking from the front of the bike. Keep the key turned and pull straight up on the back of the seat. There is a tab on the front right behind the tank, so when you are putting it back make sure that tab goes into the slot first. Wow, when you get the seat off you will also find your emergency tool bag! I have royal star tour classic #41. Good Luck!
SOURCE: Fuel tank capacity & range 97 yamaha royal star motorbike
4.8-gallon, teardrop-style fuel tank (including a 0.9-gallon reserve)
It has a cruising range of more than 170 miles (273.58848 k)
SOURCE: Clutch is slipping is there an adjustment? 1997 royal star
Yamaha has a curved washer style clutch spring that it uses for this model. These have been prone to slipping from day 1. Normally when you get on the throttle hot and heavy. A new spring will help the situation for a while but you may have to replace the clutch pack to get more pressure through out the clutch pack if the bike has high miles on it. Maybe the dealer would know if the VMAX spring is heavier and would work as a replacement.
SOURCE: Clutch slave cylinder bleeder location- 1997 Yahama Royal Star To
It's located under the left rear cylinder side cover. Loosen the three bolts holding the side cover to the cylinder; you'll find a "trapdoor" into the crankcase. Open the "trapdoor:, and the cylinder bleeder will be immediately beneath it.
