Amana PTH 123e35 model
SOURCE: Error code when running Apple Hardware Test
Its an issue with the hard drive in the lower slot. The volume may be
corrupt of the drive could be physically damaged. Did you install the
bottom drive? is it the drive with the OS installed?
What does SMART statues report in DISK UTILITY?
Hard Drive/Application/Utilities/Disk Utility
Let me know.
SOURCE: whats is the f1 code mean on the dash
Go here and read the forum: http://www.gixxer.com/forums/showthread.php?t=174828
SOURCE: Acer Aspire E380 won't start. When powering on the
plug out the power cable connected in your CPU and replug it again still its not working you need to change the power cable
SOURCE: DOES ANY ONE REMEMBER HOW TO PROGRAM A AMANA
Press and hold up and down arrow at same time -press off twice to get into program mode (should read C1) -press heat button to scroll to C2 the use up arrow to scroll through options. You want to set it to read-out "On" then press off to set. This should be the continuous fan mode.
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
