Ben Nasralla Posted on Jul 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon photocopier ir3035 error #899
Keep getting #899 error intermittently on photocopier when using send to email. All ports are setup correctly, need someone with a bit of knowledge with these types of machines, have same machine setup at different address with no issues.
Lenin Hudiel
Level 3:
Master:
  • Canon Master 934 Answers
  • Posted on Sep 11, 2019
Lenin Hudiel
Canon Master
Level 3:
Master:
Answers
934
Questions
0
Helped
507827
Points
7817
Check the network settings in your copier mchine
5 Related Answers
Anonymous
  • 82 Answers
  • Posted on Apr 06, 2008
SOURCE: Canon imageRUNNER 5000 scanner
yes it can if you have the scanner driver borad loaded in the machine
Thank You,
Mikey
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Apr 14, 2008
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
A
Anonymous
  • Posted on Jul 17, 2008
SOURCE: Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
A
Anonymous
  • Posted on Feb 23, 2009
SOURCE: Changed email hosting, now scan to email does not work
I'm confused. Are you saying that the programmed addresses don't work, but if you manually enter an address you can send?
Was your Gmail ( or another Gmail) account formerly the account to which the machine's settings were associated?
In order to use the scan to email, whatever settings have changed in your main email account, for example: username, password, SMTP & POP servers, etc, must be changed to match.
I am prettty sure you may have some difficulty, however if your new host uses Email encryption (SSL) , because I don't think that machine is compatible, so you may have to (somehow) configure an extra email account within your Outlook, or whatever you use that does not require authentication.
Anonymous
  • Posted on Apr 20, 2009
SOURCE: Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Error code e000225-0001 for canon I r 3035 what I do pls. help me
The light intensity of the CIS is faulty.
During DF stream reading, the sheet-to-sheet light intensity is faulty.
Disconnect and then connect the flexible cable. Replace the following as necessary: flexible cable, CIS, reader controller PCB. Canon iR3035 Error Codes List page 3 from 16
1helpful
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
I cannot get the email settings to work I keep getting error message "Unaleble to send text message please verify email address" but the email address was correct!
Hello. Check the settings for your Outgoing Server. This includes the Port Number. Try Port 587 for SMTP.
Check the box that reads My Outgoing Server Requires Authentication. Choose Use same settings as my incoming server.
2answers
How to fix error e000202-0001 for canon ir3035?
How to fix error E000202-0001 for canon ir3035
2answers
I can not send e- mail out can you help
Simply use smtp2go.com as your outgoing mail server and never worry about problems sending emails ever again. Setup takes only 2 minutes and involves typingsmtp2go.com into your email software's settings. Send from anywhere in the world - from home, the office, New York, or even Guatemala!
18helpful
2answers
How to set up my gmail account on Motorokr E6
Do the satting given..
Send Setup:
Server: smtp.gmail.com
Port: 587
Email: <my>
Nickname: <my>
Authentication: on
Username, Password, etc: Same as Receive Setup
Use SSL: Yes
Receive Setup:
POP3
Server: pop.gmail.com
Port: 995
User name: <my>
Password: <my>
Keep on Server: checked
Incoming Messages Sizes Limit: 512K
Use SSL: Yes
1helpful
I have a canon photocopier IR3035 I want to check how many copies it has done it then. How can I get that information in that copier.
Press the counter check button on the control panel, located just above the stop button, right hand side. (page 1-14 in reference guide)
The host 'reynolds4242' could not be found. Please verify that you have entered the server name correctly. Subject 'hi', Account: 'reynolds4242', Server: 'reynolds4242', Protocol: SMTP, Port: 25,...
Seems you are using outlook to send your email. You might just have clicked their "mailto" linked that's why outlook popped up with the recipient's already written.
If you don't have your own email account, you can't you outlook to send email. You better sign up with yahoo mail or google mail then continue sending your email.
Anyhow, if you have your own email account, you must have setup your POP3 mail server and SMTP mail server correctly. It somewhat looks like this:
POP3 mail server: mail.yourdomainname.com
SMTP: mail.yourdomainname.com
Regards!
1helpful
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
3helpful
2answers
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
old marine
old marine
ZJ Limited
ZJ Limited
