SOURCE: curtis klu tablet needs unlocked
if you have an associated itunes account on your pc you should be able to connect it and unlock it that way.
After a few attempts to guess pattern it should prompt for the gmail account assigned to the phone. Then allow a pattern reset and confirm.
SOURCE: Hi...my goibii 7inch tablet is locked with a
look for your tablet on the internet and find the lock overide sequence keys
SOURCE: My daughter Tryed unlocking my pattern on my 7'
Keep trying the unlock pattern. Once it rejects you it will ask you to sign in to your google account. If you don't have a google account type "null" in the user name line and "0000" for the password. I was locked out of my android phone and used this to get past the unlock pattern and back in to my phone.
SOURCE: how do i reset my tablet
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button,Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished.
