K1 pulls in and unit produces steam but k2 does not pull in. It has no voltage to contactor coil. what has to happen in order for this contactor to pull in?
Likely 2 stage heat. If you raise the temp, say, 10 degrees, it should call for 2 stages of heat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: intertherm outside unit - s3ba-036k - does not run
Measure the voltage across the line. The outside unit normally runs on 220 Volts. Measuring each side of the line to ground will give 110 Volts. If your outside disconnect is of a fused type one fuse could be blown. If a fuse is blown on one side of the line you will read zero volts differential across the line.
Check the type of fuse used in the disconnect. Make sure the proper size time delay fuse is installed on both sides of the line at the disconnect.
SOURCE: What do the radar codes
Hi bb360 - X1, K1, K2 etc indicate the radar band the police are using and the signal strength you are receiving. For instance, if you were to see a X5 come up on your display it would mean the guy is right on top of you and it may be too late to slow down. In case you don't have a manual I've included a link for you. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.cobra.com/downloads/manuals/XRS9330_MANL.pdf
Jeff
SOURCE: application to unlock a motorole krzr k2 AT&T cellphone
You need an unlock code you can google for sites that offer them for a small fee or search for someone in your area with a Smart-Clip
SOURCE: pilot fires then quickly shuts off how do I pull a
Pilot must heat the thermocoupler a couple of minutes before letting go of the button. The coupler controls the main valve.
SOURCE: Unit is GQ3RA-036K with H3HK010H-01B heat strip. I
you need to ohm out the heater elements. Its the ohm reading that will give you insight as to whether or not the coils are bad.
When ohming out the elements, be sure to tag and disconnect all electrical leads to the meter...otherwise you will get a false reading.
If the elements read OL, then they are bad. Also, check to see what the voltage is to the heaters. Ensure the voltage supplied corresponds with the unit dataplate.
